by bobspears1 » March 14th, 2012, 7:05 am
Ok, I see the reasoning posted by all.And I like some ideas,and we need to do it. Been shot down before! Holding your line should have been learned long before now, good point. Shorter picks, slower speeds,another good one. Adding plain water,still not convinced; Introducing heat ? Creating gaps around the perimeter for the air/snow to escape? I thought an economical way would be // take a road compactor,, mount a couple of torpedoe style heaters to it,get it hot keep it hot and use it after or during the plowing and prior to any big number of sleds, race.Maybe 60/40 mix in the rollers...? heck park it on a bonfire partially.Less than jet A,and the other proposals,and built,needing a minor attachment built for the heat source. Keeping the bales from freezing needs to be addressed and we all know that is just plain work. Since urea is out,sadly,then we need to look at enclosing the tunnels and flaps better,plastic might work from the front of track to rear,and down to the ice.
