by Mr.Pipe » April 5th, 2014, 7:22 pm
If you look at the group of riders that typically win Champ races, you would see that they fall into the 165 to 195 weight range. Under the proposed weight rules, as John mentioned, these drivers would add little or no weight to their snowmobiles. So there would be no measurable performance correction between that group, and lets say the 225 lbs racers that feel they are not currently on even ground. The rule would however add considerable weight to the drivers under 150 lbs, that currently seem to be at a slight disadvantage in their ability to muscle the Champ sleds around the track. Please correct me where I could be wrong, but where have the drivers under 150lbs shown a performance advantage?. Now if you add another 20-30, or maybe 40 lbs to some of these light drivers snowmobiles, do you not see the chance that they may get discouraged and not continue racing. ...and what has changed for the heavy drivers feeling they are at a disadvantage to the guys in the 165-195 lbs range that have, and likely will continue to finish at the front of the field....nothing!
A combined weight rule does not solve any problems as I see it, and in fact creates a few new ones.
Do the +200 guys deserve a break? yes, maybe they do, but to add weight to the light guys is not a good solution.
Giving the heavy guys a bit more power by carb size is a more logical solution. At least one worth testing in the upcoming season. For example, if a guy between 200 and 225 lbs was allowed 34.5mm carb bores, and a driver between 225, and 250 lbs was allowed 35mm carb bores, it would give the heavy guy a performance correction vs the racers that are 165, to 195 that currently finish well, while not hurting the light guys that don't seem to currently have an advantage anyway.
I do want close, even racing, I just don't want to make changes that don't solve the problems, and may in fact hurt the sport, or make us lose any racers, or potential new racers considering moving up to Pro Champ.
Darcy
