We all know that Champ could use a few more competitors at most events. The question is, how do we make it happen?
When you look at the growth of F-500 compared to Champ in the past 5 years it's quite clear that cost is likely a HUGE factor.
NO, I am not proposing any changes to the current Champ rules!
I am proposing a 2nd OPTION for a less expensive Champ sled that would be allowed to compete in the current Champ class.
Lets call this "proposed lower dollar sled" Option-B
This sled would follow all current Champ Rules except the following changes:
#1- 116 inch min. track length, NO SOFT RUBBER TRACKS!!
#2- Absolutely no titanium or carbon fibre anywhere on the sled
#3- no belt drives, chains and gears only.
#4- 385 lbs. min weight
#5- 36mm mikuni round slide carbs to offset difference in weight and rotating weight {only about 2-3hp difference}
with my 30 years of building chassis and engines I firmly believe these 2 Champ sleds would be quite equal, with maybe a tiny advantage to the Original Champ.
OK guys, tell me why this won't work to encourage a few lower dollar teams to try Champ racing. John Hooper
