by ZRT800 » April 3rd, 2002, 3:08 pm
Good to hear you're ok! Doesn't sound like you got physically hurt - just your ego!! You got lucky, & so did your buddies!!!
I hit a pressure crack back in Feb. Launched the sled & it landed on it's tail. $2000- cdn damage. I got lucky (injury wise) & I learned my lesson!
So, you sunk your sled. Can you get it out? As long as you shut your sled off before it sank, it'll be fine. Just pull it up as soon as possible! Once you get it up pull out plugs (PROVIDED IT'S NOT EFI), tip on it's right side, & pull it over until the water stops spewing from the plug holes. IF IT'S EFI DO NOT PULL THE CORD UNTIL THE COMPUTER IS 100% DRY (you'll fry it)!!!! Next, drain everything!!!! If it's EFI, don't pull the cord until the computer is 100% dry. If it's wet, you'll fry it! Other than that, clean out the seaweed & loon sh*t, drain the carbs, fuel pump, lines, tank, oil container, pipe, canister, chaincase (take apart & clean then refill). Re-fill oil tank, put mixed gas in the gas tank, you may need new plugs, pull the cord & she should fire up! If it went down running - well you may be f*cked! Engines don't like hydraulic lock ups! Your guages will probably be shot in a year or so. Other than that, you should be fine. Get it running & run lots of oil through it. Another thing to remember is the magneto, if water sits in there it will rust or corrode the coils. Get it running & burn off any moisture. If it's down there for awhile, take off the mag cover & dry out the mag & coils.
Where I ride, running water is part of every ride, eventually you'll sink. Sleds go down all the time. some are easier to get running than others, but what I've described is the full out approach to reviving your sled. Your seat will be a b*tch to dry, can't help you there. Once everything is running well, give it a WD-40 bath & a good grease job!
Best of luck!!
Who said Cats can't swim?!?
