by mnsnowboy » November 6th, 2002, 1:01 am
Hey guys: Here's some real world experience. I have a '96 F-III (Heavy Pig) and I have triple individual Stingers on my sled. This is not the canister silencer obviously, and like the guy with the Ultra, yes, the weight savings are unbelieveable. It is X-Tremely loud! Sometimes I wear earplugs every other day because I am too lazy to put the factory can back on. ANd yes, these are made by MBRP. I do not know if you can even get these any more, canisters are way more popular and practical. I CAN tell you a couple things, this sounds funny but my sled seems to start a lot easier with these Silencers. I also notice a little more bottom end snap, especially since any extra bottom end is easy to notice on a triple. Other than that, I would say it is mostly a huge weight loss and an unbelieveable screaming exhaust gain! I think a canister would save you a lot of weight still and make the noise that you want. I would not modify the stock pipe either because you do not want to change the expansion chamber unless you know what you are doing. And if you cut apart the silencer to rip the fiberglass out, I hope that you are good with a rivet gun because if not it will leak like a sieve and smoke under your hood! Good luck!
Kick ass!
[IMG]http://img.photobucket.com/albums/v410/mnsnowboy/rocking.gif[/IMG] [IMG]http://img.photobucket.com/albums/v410/mnsnowboy/hellyeahFireIcon.gif[/IMG][img]http://img.photobucket.com/albums/v410/mnsnowboy/bobZilla.gif height=90 width=20[/img]
