Pipes
Pipes
Postby ZRT7c » August 30th, 2003, 3:45 pm
I was wondering what kind of pipe would be a cheap pipe but a good pipe for my 96 ZRT 600 it needs to be loud Thanks
[green]STAY GREEN[/green]
[img]http://www2.propichosting.com/Images/502164/1.jpg[/img]
ZRT7c
Pipes
Postby catdaddy » August 31st, 2003, 2:59 am
Getting rid of the stock can will do that. Heck the stock can wasn't too bad but was a little heavy. As far as pipes go, I doubt you'll find anything new for less than $650-stick with the stock and go with stingers.Aftermarket pipes only increase horsepower in a higher r.p.m. range where you have to be careful with a "stock" triple.There are several small mods to be done with the ZRT600 without opening the engine that will really wake it up! Make sure you have a good clutch kit. Are you running any picks? These sleds with the right tuning/setup will still to this day give azz spankins'to many a sleds! Good luck!:)
catdaddy
Pipes
Postby ZRT7c » August 31st, 2003, 5:35 am
ok thanks catdaddy yes im running picks but im not to sure how many because i just bought the sled off a guy i appreachate the help
ZRT7c
Pipes
Postby indysp440 » September 1st, 2003, 3:26 am
i have a new set of pipes for a 96 zrt for sale let me know
tcrash@charter.net
[img]http://www.danasoft.com/vipersig.jpg[/img]
indysp440
Pipes
Postby ZRT7c » September 1st, 2003, 4:24 am
ok thanks indy but i think i might go with a new can i was talking to a couple of snowmobilers and they said the can is the way to go and cheaper but ill let you know if i change my mind lol thanks
ZRT7c
Pipes
Postby AC600 » September 6th, 2003, 7:44 am
I have PSI pipes on mine. They are loud, but sound great. They run at 9250 rpm.
AC600
Pipes
Postby ZRT7c » September 6th, 2003, 10:45 am
Cool do you have a zrt 600? ya i here psi pipes are pretty good but i wasent sure if you put pipes on your sled if you have to mess with any other settings i was just thinking about a can because there loud to
ZRT7c
Pipes
Postby catdaddy » September 6th, 2003, 11:19 am
There is a "clean" used DG silencer on e-bay right now-was around $130 u.s. earlier this morning.
catdaddy
Pipes
Postby ZRT7c » September 6th, 2003, 4:56 pm
ok thanks catdaddy
ZRT7c
