need help with 583 rotax r.a.v.e
Postby nitro420 » February 27th, 2004, 9:08 am
I just pucsed a foumal z 583 rotax it ran for my test run before i bought it now it runs but only when it wants and the most i ve her run stedy is 10 khm then it just dies and wont start it get spark ive taken both the carbes and fuel pump apart and cleaned the seem to be both in good conditon when it run it runs good and dies with no warning if any of u have an ideas on what i should do pleas tell thanks you for ur time
nitro420
Postby snoguy14 » February 27th, 2004, 1:59 pm
check for wiring faults .you said it dies have you checked for spark when it dies?Is it getting gas when it dies?What colour are the plugs?Check these things and post your reply
I'm not fast, your just slow.
snoguy14
Postby Wildcat700EFI » February 29th, 2004, 3:50 am
I know someone that had the same type of problem on their 670 MKI. The problem was his electric shield hook up for his helmet. Where ever he tapped into for current for his helmet screwed up how the sled would run. Look electrial.
SkiCat
Wildcat700EFI
Postby nitro420 » February 29th, 2004, 11:05 am
it get lot of spark when after it dies and usally after it dies its fluidd the plugs coulor are the spark is blue and the plugs are brand new olny have ten mintuse of run time but are black i usally jus take a wire brush and wipe that black******of before i try to refire it i think that it's the jets i just dont know what that will set me back and i dont want to replace stuff i dont need
nitro420
Postby sledwrench » February 29th, 2004, 2:01 pm
I have a 583 with rave, and it IS a plug eating pig. When it runs, its quick, but on a cold start up, I can fry a new set of plugs in 5 minutes!! You can clean the rave valves, but its more likely just the way that sled is. I started to rejet it a little leaner on the idles, and the mains, but it got warm outside, so I quit. If I start it with maybe 1 squirt of the primer, and ride it slowly, without hammering on it, I can get 1 set of plugs to last maybe 5 rides. Once they foul, I throw them in the woods. Good luck
Postby doo4sno » February 29th, 2004, 2:41 pm
do a compression test.most likly you have a slight siezed piston.ck side that fuel pump vac hose is hooked to.
ed nedeau
doo4sno
Postby nitro420 » March 1st, 2004, 5:38 am
what type of comprison should the 583 rotax have i check and it has like 80 and 100 i think that this is a littel low and about the plug i heard from a friend that if i put br8es it will burn hoter nd the plugs will last longer dont know for sure but i think it worth a try
nitro420
Postby FreezurBurnt » March 1st, 2004, 5:57 am
That might be your problem
125-135psi is what that engine should have
I have 125psi each side on mine
80-100psi is too big of a gap between sides
FreezurBurnt
Postby ionlyrideskidoo » March 3rd, 2004, 8:44 am
the compression should be 150 on a stock 583. take the cylinders off and inspect the piston and cylinder walls.
ionlyrideskidoo
Postby nitro420 » March 3rd, 2004, 8:57 am
so this lag of comprison is the reson why it a horor to start and why it dies after its runing kuz i dont want to replce stuff that wont fix the problem and i had people say its the jets, its eltrical it,s the sparck plugs the only thing that seems to be wroung is comprison is low and im about to take this ski doo and drive off a clif while on fire
nitro420
