by nab4me » September 22nd, 2004, 7:00 am
If you are looking to switch the engine, i would see if the engine mounts are the same or if the 440 will mount onto the 340 mount, if the bodies are the same you shouldn't have a problem using all of the 440 exhaust. you probably need to use all of the 440 wiring and carbs and put air filters on in place of the air box. what did you do blow up the 340 or just looking 4 more power?
