clutch?
clutch?
Postby bigj » January 25th, 2005, 5:36 am
Hi
I was out riding lastnight and my sled started to make a wierd noise. It was like a fast clicking that would increase and decrease with engine speed. I am trying to diagnose it and i am thinking it night be the primary clutch, as thats generally where the sound seems to be coming from. Do these symptoms ring a bell with anyone?
It has an aftermarket Comet 108ex clutch
bigj
clutch?
Postby rabeb25 » January 25th, 2005, 5:59 am
I really hope its not rod knock. Hold a screw driver to the bottom of the motor and see if the clicking is actually knocking coming from it.
rabeb25
clutch?
Postby jpiler » January 25th, 2005, 7:28 am
Bearings usually make a clicking noise before they let go altogether.Given the location of the noise i`d say check clutchside jackshaft and driveshaft bearings.Possibly an engine bearing but less likely.I have no experience with comet clutch`s so could be that ?
jpiler
clutch?
Postby buster49er » January 25th, 2005, 9:23 am
whould it even do it when the track wasnet turning? like at idel?
[IMG]http://img143.exs.cx/img143/8822/skidoo7uh.jpg[/IMG]
[IMG]http://img58.exs.cx/img58/7597/vmax2pn.jpg[/IMG]
[b]If You Don't like Beer Don't Live In Canada[/b]
buster49er
clutch?
Postby bigj » January 25th, 2005, 9:54 am
Ya it would do it whenever the engine is running
bigj
clutch?
Postby bigj » January 27th, 2005, 5:04 am
Anyone got any ideas?
If i take the clutch apart what should I look for?
I've never done anything with snowmobile clutches before, to be honest i don't even fully understant how they work.
bigj
clutch?
Postby jpiler » January 27th, 2005, 10:40 am
If you have a clutch puller pull the clutch off and clean with parts brush and a drain pan of acetone available at any paint store or large chain store or farm store,probably even an autoparts store.
If you cant get the clutch off throw a towel under the clutch and spray clean the clutch with 2 cans of contact brake cleaner.Blow dry with compressed air if possible.
jpiler
clutch?
Postby bigj » January 27th, 2005, 11:04 am
do you have to take it apart and clean each individual part, or just soak it?
Also will varsal work?
I do have a clutch puller so thats not a problem
bigj
clutch?
Postby jpiler » January 27th, 2005, 11:10 am
Whats varsal normally used for ? pull the clutch and disassemble just enough to expose all parts to be cleaned , which is probably just the cover.Leave clutch mostly assembled clean with parts cleaner brush and cleaning solution.Use something like a oil drain pan with plenty of cleaning solution.
I looked up Varsal and it appears to be a lubricating cleaner ??
Dont use any type of lubricant.You want a no residue cleaner.
Inspect the clutch for unusual wear or damaged spring.
jpiler
clutch?
Postby bigj » January 27th, 2005, 11:22 am
The reason i said varsol is because i have a parts washer with varsol running through it.
bigj
