by Jpak 7p » March 29th, 2005, 6:09 pm
Can a 96 Formula S even get air on a jump. I don't even think it is possible to ride that sled hard. What is the top speed? I can understand why not much maintenance is required for a 380cc sled. But if you had to replace the muffler, that would be caused by the fact that you didn't do anything to maintain your sled or keep corrosion off of it. WD-40!!!!!!!!!!!
Hey, RXL-XC7_RIDER, over the years, I have had the experience with a 92 650, 94 RXL short track, 98 XC7, and 2004 XC7. All sleds have been great, but all except the 04 XC7 have had their problems. The 92 650 was kick A$$ when we first got it. But for some reason after several years, it developed a overheating problem. Might have been from aftermarket skis and a widened ski stance, but I doubt it. We did replace a radiator cap that came apart, but we could not find any flow problems in the cooling system. So we put a radiator in it and sold it to get the 04 XC7. The sled had awesome weight transfer and would pull skis in the air in almost all snow conditions, without picks.
The 94 RXL initially had problems with engine alignment and throttle position sensor. Once these problems were solved, this sled has been rock solid. Didn't sound as cool as the 92 650, quieter and a little better handling.
The 98 XC7 had problems from the factory. The engine came apart at 465 miles. Something about the key for the timing came out and the timing was advancing and retarding on its own. Also, one of the reeds was out of its cage, and would let extra fuel into one of the cylinders, which helped cool down the piston, and keep it from coming apart for a little while. Locked it up a couple of times, but would restart after five minutes. Ran like Sh--. Then I had dealer/Polaris problems. My sled was in the dealer for 5 weeks. Almost lost it for the whole season. The dealer stated that Polaris was out of stock on the head, and Polaris also wanted to know why the sled took 465 miles to finally come apart. Thankfully for my mechanic at the time, he was able to set Polaris straight, and suggest that I go with and aftermarket head to get the sled back out. Funny thing, the stock Polaris head showed up the same day I was picking up my sled, I was told it wouldn't be in until May. Otherwise, this sled has been great, with little mods such as clutch kit, V-force reeds, SLP boost bottle and head, it has been a rocket. Still very competitive with new sleds. Will actually beat the 04 XC7 by a length or two.
The 04 XC7 is night and day compared the the 98. The suspension and comfort is that much better. Until this year, I thought my 98 was pretty decent in terms of suspension. So in another year, the 98 will be going up for sale, and I plan on getting a Switchback, or maybe the ugly Fusion. I want to stay in the 700 range. Overall, my brother and I have enjoyed these sleds, and with the maintenance my brother does, it kept all sleds competitive and problem free on almost all of our trips.
