jet question
jet question
Postby MxZx440 » November 6th, 2001, 5:46 am
what are the stock jets sizes for my 2000 mxzx440?
The reason I ask is because It has a bogg at about 2000-3000rpms.wodering if I should go up a size on the mains for safety.I bought it used so I don't know if the jets where changed by the previous owner.
Thanx,
MxZx440
Its all fun and games till someone gets hurt=Then its hillarious!!!
MxZx440
jet question
Postby indy500 » November 6th, 2001, 7:23 am
there should be a a spec sheet that came with your owners manual that shows what jets it came with, if not haul off the carbs and look at the bottom of the main jet to see the numder on it,
jet question
Postby skidplate » November 6th, 2001, 9:36 am
usually your main jets will not be in effect at this low of an rpm. your sled shouldn't be engaged till 4,000 to 5,000 rpm maybe your floats are stuck or something get out your manual and check for the specs on the air screws, idle speed etc.
skidplate
jet question
Postby MxZx440 » November 6th, 2001, 4:04 pm
Could it be because its not totally warmed up when It does it,Like a few seconds after I start it I'll rev it up a little and it does it.Plus it seems to Idle really low But I dont know what the idle is because its a Ski-Doo and the tack just falls to 0 when it goes under 1000.Maybe its just the idle screws aren't set right.
Thanks for the info
Adam
MxZx440
jet question
Postby ice_racer_440 » November 6th, 2001, 4:17 pm
It shouldnt drop down to 0. It should idle at about 2000rpms or more. It should engauge at about 5 to 5500. And the bog it sounds to me that it aint warmed up enough like you said.
Ice racing kicks
#11
ice_racer_440
Users browsing this forum: No registered users and 6 guests
