how to make seld higher in rear
Postby indy500 » November 7th, 2001, 4:55 am
how do i raise up my exra 10 suspencion, i dont have thoes plates on the tunnel with the dual mounting holes?
98 indy 500,
indy500
Postby Luv2sled » November 7th, 2001, 4:59 am
Do yourself a favorite and light a stick of dynomite under that piece of s**t. That's sure to raise the back end up a bit. LOL....Just kidding buddy.
Luv2sled
Postby Luv2sled » November 7th, 2001, 5:01 am
Sorry Indy, I thought I was on the trash board. I really have no idea.
Luv2sled
Postby michahicks » November 7th, 2001, 6:17 am
The xtra-10 is one of, if not THE, best supensions
available. Don't have a clue why you might want to modify it. Set it up for your weight and ride it, unless you happen to have an extra thousand dollars or so that you would like to throw at it.
If so get an M-10. That's capable of raising the back up high enough to make your sled look pretty stupid.
michahicks
Postby indy500 » November 7th, 2001, 7:10 am
Luv2sled i hope you dont drive a yamaha or soemthing :)
98 indy 500,
indy500
Postby Luv2sled » November 8th, 2001, 12:07 am
I do drive a yamaha and have three CATS (but I rarely admit it).
Luv2sled
Postby swago » November 8th, 2001, 4:16 am
your sled is designed to run with the geometry of the suspension as it is sold with from polaris. It is adjustable in many areas. you cant just rivet on some plates to your tunnel and then bolt the skid in there because you will throw off the geometry. The front end wont steer, it will plow or push instead since the weight is transfered to the front. You will be loose in the backend too since the weight transfer is now way out of wack. The Xtra10 IS A GOOD skid, adjust it to your weight and ride it.
swago
Postby indy500 » November 8th, 2001, 4:56 am
yea im gona leave it alone
98 indy 500,
indy500
