Pipes for xc800
Pipes for xc800
Postby blurrxc800 » November 9th, 2001, 4:39 am
Anyone out there found out what the best set of pipes is for this rig? PSI appears to be making the biggest power gain , but any input for some real world numbers would be much appreciated. It's an 01 (non-ves)model by the way.Had a set of SLP pipes on a 98 700 and had good luck but kind of leaning to PSI this time around.
Anyone had an experience out there?
blurrxc800
Pipes for xc800
Postby Fox click » November 9th, 2001, 5:52 am
SLP,Hot Seat been around a while, Dyno Port,
Fox click
Pipes for xc800
Postby 800 XC » November 9th, 2001, 8:04 am
I'm also looking for pipes for my 01 800 XC. From what SLP says you cannot use their pipes on Pump gas so I'm will probably go with PSI as well. I don't know if PSI has a clutch kit for the roller clutch though so I may get that from Goodwin. Does any one have any experience with this combo?
800 XC
Pipes for xc800
Postby blurrxc800 » November 12th, 2001, 12:47 am
PSI does have a clutch setup made directly for their pipes including all the necessary parts for 189 bucks. You don't have to change your heads with their pipes supposedly. Wish i could get a little more info before i decide to buy.
blurrxc800
Pipes for xc800
Postby turbo89 » November 14th, 2001, 7:34 am
Have a set of PSI pipes for the 800 for sale
Brand new in the box, also have head and clutch
kit
they work great, a friend has the same combo,
head set, reeds, PSI twin pipes, clutch kit
and a he can pass a T-CAT.
turbo89
Pipes for xc800
Postby Xtreme XC » November 14th, 2001, 8:07 am
SLP's new single pipe for the '02 XC800 put's out 13hp peak and it ceramic coated, I just recieved mine today. The SLP twins for the '02 are saying 21hp but only come with a ceramic coated can.
Pipes for xc800
Postby swago » November 16th, 2001, 12:08 am
just wanted to let you know that when the aftermarket pipe guys say there is a 21hp increase you can count on less than that in your ride. They set up the machines to give the highest reading possible by leaning the bugger out to the verge of melt down. if they were to run it down the trail for any length of time it would sieze. No question, pipes offer more ponnies, but dont be fooled by the numbers posted by the manufacturers. :)
swago
