by thekrust » January 20th, 2002, 7:50 pm
I've done quite a bit of work on the 670, including dyno testing several sets of pipes. The only pipe that ever gave consistant hp increase were the Crank Shop units. The other thing to remember is that Ski-doo builds a very good factory pipe and the best gains are only 3-5hp and near 9lbs of wieght. The other option is to but a B&B eliminator pipe on, that'll save you about 8lbs, and sounds almost as good as twin pipes.
If you want to make it go, I would cut the head down put a 501 spec carbon fibre rotary valve and bore those 40mm carbs (can safely take them to 43mm). I also used a .040 shim under the cylinders, big difference
*This Message was edited on 21-Jan-02 12:53 AM by thekrust*
Ride on!
