by ice_man_cometh » January 15th, 2002, 2:03 pm
yeah. its on the throttle. when you hit the throttle, pull it up or push it down. that should cut off the gas flow and make it bog. by unplugging the wire that contains the kill switch, so you'll lose that crappy useless valve and your kill switch.
~john~
