by Maniac » January 23rd, 2002, 7:59 am
Ok, no e-mail yet, guess I looked too soon. Anyways heres what happened.
I was running across a lake when I suddenly heard a weird squeaking noise. It soon went away and I kept on going. Suddenly my sled started to develope a slight vibration at high speeds, but it still ran and at low speeds it was non-existant.
That's about all that happened, and it still ran fine, but I suspect that the squeaking was the bearing spinning on the crank. Also, it was the second bearing that went on mine, so the crank was still somewhat supported by the other bearings so it did not bend. Had it have been the outside I would have been in much more trouble.
Have you tried taking the clutch off and rolling the motor over to listen for bearing noise?
Pull up and down on the clutch to check for crank play.
Any vibrations while riding?
Even if it turns out not to be the bearing, I would still suggest that your friend gets the oil gallery drilled. If you bend a crank, say bye bye to alot of engine parts.
I know it's a pain, especially if you and your friend rebuilt the motor yourselves, but really it'll probably save money in the long run.
Keep me updated and feel free to ask any questions.
Let 'er RIP!!
