hey 670 experts,help me out??
Postby youno » January 23rd, 2002, 11:43 pm
about the old '94 mach 1, thanks for the advice on the frontend. how about the cylinder compresion? when i put this sled together,a couple years ago(bought it in a box--repo--)the cylinder comp. was 175-180, is that right?5% difference in the 2 cyl. i'm supposed to run a br9es plug, but keep fouling, will a br8es help. Yes this has been a project(FUN) but I got it for 325.00. And I love it. what can i do that don't cost a ton of cash to improve it. Thanks
youno
Postby Xtreme XC » January 23rd, 2002, 11:56 pm
175-180psi for compression??? That is EXTREMELY high. If that were the case you would have to be running 110 octane all the time. It takes 175psi for 110 to combust efficiently. You may want to recheck those. They should be down around 120-130psi range.
Postby youno » January 24th, 2002, 1:22 am
175#s for sure, tryed 2 different testers, what too look for?? Was also told to try BR9EYA plugs. Any input? Thanks!
youno
Postby swissbliss » January 24th, 2002, 3:12 am
TRY BR9EV, THIS PRUG WONT FOUL AS EASY,AND THE COMPRESSION SHOULD BE AROUND 150 PSI ,PERFECTLY NORMAL FOR A 5 PSI DIFFERANCE ON THE 670 MOTOR.
jamie stancil
swissbliss
Postby thekrust » January 24th, 2002, 7:32 pm
Please explain how you got this # I have never seen a 670 with that much compression.?? something is not right.
Ride on!
thekrust
Postby swissbliss » January 24th, 2002, 10:08 pm
THE HEAD ON MY 670 WAS SHAVED AND THE COMPRESSION WAS 170 PSI ON MAG SIDE AND 175 ON PTO SIDE. THE PROBLEM WAS, I WAS TOLD I COULD RUN PUMP GAS AND I WOUND TOASTING THE MAG SIDE.I SHOULD HAVE PUT OCTANE BOOSTER IN IT, PROBABLY WOULD HAVE SAVED THE MOTOR!
jamie stancil
swissbliss
