by snoguy14 » January 26th, 2002, 3:56 pm
try to remove the worst of the damaged surface with a fine wet- dry sand paper,then use the seal and either loctite blue or what i use is loctite gasket maker it will fill in up to a 10thou indent
I'm not fast, your just slow.
