by Snosport » February 4th, 2002, 10:38 am
I had a couple of 94 Panteras with the same front end. When I got them they were horrible. Darted all over and tried to follow every rut in the trail. The fix that worked for me was to align the skis so they are as close to parallel as possible, if you have threaded collars on the front shocks set them to the setting recommended in the manual. The Panteras were recommended at 3/4 to 1 inch of threads showing below the collar. The thing that made the biggest difference was when I found "ski savers" from Bergstrom Skegs. This is a plastic strip that mounts between the skeg and the ski. Really helped with the darting and following the ruts in the trail. I put them on one of the Panteras and not the other at first and there was a night and day difference. You can find Bergstrom info at Bergstromskegs.com. Phone # is 800-237-5347
