Compression Test
Compression Test
Postby pleaseletitsnow » November 2nd, 2004, 4:20 am
what is the correct way to test the compression and what should my 00 700xcsp be at thanks
CUT ME IN OR CUT IT OUT!
I dont care what you ride lets just ride!!!
pleaseletitsnow
Compression Test
Postby Xtreme XC » November 2nd, 2004, 4:33 am
1. Pull plugs
2. screw compression gauge in cylinder, when finger tight pull motor over 5-6 times
3. Repeat with same amount of pulls for the opposite cylinder
A 7 hundo Poo should show around 125-130 psi give or take a couple.
Compression Test
Postby Mainecat » November 2nd, 2004, 4:38 am
They both should be the same psi and the engine should be COLD!!
Mainecat
Compression Test
Postby catdaddy » November 2nd, 2004, 4:49 am
With throttle completly wide open.
catdaddy
Compression Test
Postby treewhacker » November 2nd, 2004, 5:09 am
At sea level, compression less at higher alt
[img]http://img19.imageshack.us/img19/1278/a1ugly.jpg[/img]
treewhacker
Compression Test
Postby pleaseletitsnow » November 2nd, 2004, 5:12 am
Thanks fellas i appreciate it
pleaseletitsnow
Compression Test
Postby Xtreme XC » November 2nd, 2004, 5:42 am
Keep in mind going one gauge to the next will vary in readings. No 2 gauges seem to be the same. You just want to see the same reading between both cylinders (withing a couple psi). Holding the throttle open will not change your reading vs closed.
Compression Test
Postby RWL » November 2nd, 2004, 5:49 am
Ask any rev owner....most are expert's at this! (OUCH):B
"on a still summer's night you can hear the ring's flake in a rotax engine" :o
RWL
Compression Test
Postby Johnny Skeptical » November 2nd, 2004, 11:43 am
uhhhh 'puddin' head' that is incorrect an engine should be warm so the rings are seated properly---even a leak down should be done while warm.
And that is correct about not holding the throttle open but it will reach the peak quicker if you do....within 10% between the 2 cylinders is acceptable.
[img]http://pics.greatestjournal.com/userpic/11908820/671512[/img]
BEFORE YAMAHA...
Johnny Skeptical
Compression Test
Postby treewhacker » November 2nd, 2004, 1:13 pm
Throttle should be held open.....With throttles closed you will pull more pulls to get to 100#, plus with them closed you may get innacurate readings should one slide be open just a little more.
treewhacker
Users browsing this forum: No registered users and 11 guests
