DemonGade update
DemonGade update
Postby mach1mikeM1M » December 12th, 2008, 3:56 am
Took da Gade out for a two mile little spin did a couple of plug chops and da 350's are gonna stay.Now gotsta work on da needle and pilot.Sorry Benoy no majic needles.She's running good.Didnt need a tow vehicle either.Gonna adjust the track tension and chain case got a little ratcheting noice under hard accel so should be one of dem.Also Mr Armstronged a Rave Valve bolt and da head popped off like a Dandelion dam da luck looks like Mr Drill and Ms Helicoil need to go on a date.
mach1mikeM1M
DemonGade update
Postby Pol-Cat » December 12th, 2008, 3:57 am
is there enough bolt shaft left ta weld a nut on the end so ya don't have ta drill n heli
My vision is better then my hearing...shut up and show me something.
Pol-Cat
DemonGade update
Postby mach1mikeM1M » December 12th, 2008, 4:04 am
No
mach1mikeM1M
DemonGade update
Postby GThunda » December 12th, 2008, 4:07 am
You got da touch of a baby gorilla.
GThunda
DemonGade update
Postby FiredUpRupp » December 12th, 2008, 4:12 am
Phuck dat demongay bullschit!
FiredUpRupp
DemonGade update
Postby ZR900MAN » December 12th, 2008, 4:17 am
You need a job worse than than mee mike. Here we both sit wasting time on the interweb.
ZR900MAN
DemonGade update
Postby Pol-Cat » December 12th, 2008, 4:25 am
Da gade got some gitty up n go now? I hope it's impressive, all da folks at dootalk got der reputation as expert tuners on da line.
Pol-Cat
DemonGade update
Postby 600zrtrx1 » December 12th, 2008, 4:25 am
[img]http://images.google.com/imgres?imgurl=http://i.pbase.com/u8/kayakbiker/upload/32805013.1_VillageIdiot.jpg&imgrefurl=http://www.pbase.com/kayakbiker/image/32805013&usg=__obccLAwIZNHL3lnxE119qhr2TTA=&h=639&w=517&sz=56&hl=en&start=16&sig2=rxvz9yhWcNXPswYOhZ3K2A&tbnid=_eHm20IvdGcscM:&tbnh=137&tbnw=111&ei=RA8_ScjOCpeu8QTkntHNDA&prev=/images%3Fq%3Didiot%26gbv%3D2%26hl%3Den%26sa%3DG[/img]
600zrtrx1
DemonGade update
Postby mach1mikeM1M » December 12th, 2008, 4:29 am
True dat PC!
mach1mikeM1M
DemonGade update
Postby Uller God » December 12th, 2008, 4:32 am
Ratcheting chain case, ohhhh no! Get some more Dootalk tuning help.
User avatar
Uller God
