Pro x 440
Pro x 440
Postby SKS 700 » January 24th, 2002, 5:59 am
I just was wondering what the top speeds for the 2002 pro x 440 liquid and pro x 600 were. I've heard a lot of different numbers i just wanted to get things cleared up.
SKS 700
Pro x 440
Postby 885 » January 24th, 2002, 12:27 pm
We've seen 104 mph with a gps while lake running and setting up for Cross Country Ice Leman...and also had 104.8 mph on radar. All depends on good air density and temp. Those numbers were with the 02 Pro X 440's. Haven't check the Pro X 600's, but they are a bit faster at times. Hope the info helps.
885
Pro x 440
Postby 600 PRO X » January 24th, 2002, 1:42 pm
WHAT KINDA CHANGES DID YOU DO TO SET IT UP FOR CROSS COUNTRY I AM GOING TO GET MINE AND WAS JUST WONDERING WHAT YOU CHANGED
2003 SKI-DOO 440 MXZX REV
600 PRO X
Pro x 440
Postby 885 » January 24th, 2002, 11:56 pm
Changed the tank to the larger tank....get the kit. I changed tank and steering loop, but keep the handle bars forward by putting in a block so a person can still go into forward stand up. Also switched to low lug track off a 99 edge. Geared up....played with a lot of gearing....depends on your weight what will seem to work best. The gearing I have is a bit lower than my friends, but I am shifting the clutches out full to get better speed. As luck would have it, there isn't enough snow to be in the ditches and woods yet so we are Ice racing on the lakes. This is not necessarily my favorite since the set up has to be so good and there isn't a lot of room for error in the corners. Also changed pilots to 30's and dropped the needles. Jetting has been stock alot....using race fuel. Get the low octane head kit if you are going to trail ride. Just have to install the head, re jet and back down the timing switch one notch. Hoping for snow.
*This Message was edited on 25-Jan-02 04:59 AM by 885*
885
Pro x 440
Postby 600 PRO X » January 25th, 2002, 1:56 am
DO YOU REALLY HAVE TO CHANGE THE STEERING, I HEARD YOU HAD TO TAKE OFF THE RECOIL AND CRAP LIKE THAT TO CHANGE THAT
600 PRO X
Pro x 440
Postby 885 » January 25th, 2002, 8:08 am
You don't have to touch anything on the motor....you do have to cut the recoil rope and re-feed it into the new hoop. It isn't very hard to convert everything. The kit comes with instructions. E-mail if you have questions and I can walk you through it.
885
Pro x 440
Postby Fast_XC » January 27th, 2002, 12:54 am
I'm setting up an 02 Pro-x 440 Liquuid for trail use, other than the 12 gal tank and 92 octane heads, what gearing or clutching changes should I make? What suspension changes do you recommend? Waht is the top speed with the stock gearing?
Thanks
Fast_XC
Pro x 440
Postby 885 » January 27th, 2002, 11:18 am
Check your email Fast_XC. I sent you out some info. It would have been a pretty lengthy post. Have a good one. The sled is a lot of fun this year.
885
