TX 340 engine problem
Postby Polaris_03 » March 18th, 2005, 2:22 pm
Hi guys. I just picked up another Polaris TX 340 today from a guy. I cleaned the carbs,fuel pump,gas tank, and did the works. When I started it the sled ran fine for a couple minutes. After that it started backfiring out of the carb on the clutch side. I killed the motor and started to check it out. I also noticed that the base gasket on that same side was leaking.I also checked and the crankcase is not full of gas or oil. I checked the fuel pump again and it had pressure but still won't run on both sides. Anyone has any other ideas? I am guessing a crank seal went bad on the clutch side or a bearing. Any help would be great. Thanks in advance.
1970 Polaris Charger-restored
1974 Polaris TX 440-oval racer
1975 Polaris TX 340-trail sled
1975 Polaris TX 250-ditch runner
1977 Polaris Colt 340-Rough but runs
1983 Polaris Sport 440-direct drive
1987 Polaris Indy Sport-My "Newer"sled
Always looking for TX's-complete or parts
Polaris_03
Postby sledwrench » March 19th, 2005, 1:49 am
Fix the obvious first. Base gasket should be easy on a f/a. Fresh plugs, and try again. Maybe try a compression check, hit the seal with ether
sledwrench
