Another problem...
Another problem...
Postby cory49 » January 31st, 2006, 12:45 pm
[quote=Centricity]does the motor/crankcase have drain plugs?[/quote]
I don't know for sure, but does anyone know off hand? The motor is a 1988 Rotax 377.
Cory
[b]Sledless[/b]
cory49
Another problem...
Postby cory49 » January 31st, 2006, 2:37 pm
Just went out to take a look at the sled, and there's no spark again. I'm not sure what's going on anymore....
[b]Sledless[/b]
cory49
Another problem...
Postby SRX 440A » January 31st, 2006, 2:56 pm
disconnect or jump [depending on how its wired]the wires to the key and kill switch. eliminate them both as potential probs. to start out.
SRX 440A
Another problem...
Postby cory49 » January 31st, 2006, 3:16 pm
[quote=SRX 440A]disconnect or jump [depending on how its wired]the wires to the key and kill switch. eliminate them both as potential probs. to start out.[/quote]
I forgot to mention that. I did disconnect the key and kill switch, but still no luck...
[b]Sledless[/b]
cory49
Another problem...
Postby cory49 » January 31st, 2006, 3:21 pm
Is it possible that the timing plate has come loose? Maybe thats the reason on why I have spark sometimes, then later I don' have spark. Just an idea?
[b]Sledless[/b]
cory49
Another problem...
Postby roosman » January 31st, 2006, 3:42 pm
Check the CDI box. Any cracks? Can you see the green stuff inside?
roosman
Another problem...
Postby outagas » January 31st, 2006, 4:08 pm
timming plates dont usually come loose, unless someone had taken it off, and did`nt tighten it down good. plus, even if it came loose, it should`nt stop it from sparking.
outagas
Location: Flint MI...3rd most dangerous city in the USA
Another problem...
Postby cory49 » February 1st, 2006, 2:36 am
I'll take a look at the CDI box later today. Hopefully I don't need a new one. Damn things cost 60 bucks...And its not very old either...I'll go over all the connections again today...
Should I remove the recoil, and take a peek behind there?>
[b]Sledless[/b]
cory49
Another problem...
Postby roosman » February 1st, 2006, 3:05 am
Wouldnt hurt to look, recoil is easy enough to pull off. I would check my plug wires, coil and cdi. Also check the wires going to each of those make sure they are not corroded.
roosman
Another problem...
Postby cory49 » February 1st, 2006, 4:06 am
I checked the coil yesterday, and went over all the wires. The coil is brand new anyways with new wires and plug caps. I checked all the other wires too and cleaned them with electrical cleaner and cleaned up the grounds. I tried unplugging the key and tether cord too, but still no luck.
[b]Sledless[/b]
cory49
PreviousNext
