stx crank
stx crank
Postby jake_arcticcat » November 14th, 2006, 1:37 pm
I was wondring if the crank and cases from my 340( i think ss340), are the same as a ss440. I got a s340 motor and the cylinders are close together but the stx ones have a space inbetween them. Will my 440 top end fit onto the ss340 bottom end???
jake_arcticcat
stx crank
Postby Snojet Steve » November 14th, 2006, 3:01 pm
I looked over my 340 Exciter motor (SS338) carefully when I got it, comparing it to the older 338's and the Enticer 340s. There is a gap in the cranks and I do think the 433 will bolt to them. Stroke length should be the same.
Snojet Steve
stx crank
Postby jake_arcticcat » November 14th, 2006, 3:14 pm
thanks, does anyone know the diameter and thread of a bolt so i could make a clutch puller for a stock yammy clutch.
jake_arcticcat
stx crank
Postby AHood » November 18th, 2006, 10:58 am
no 433 top end will fit on any 338 bottom end. or vice versa. cylinder base and stud pattern is different.
jake i will check mine next week for you. i think i have a puller that worked on my yammy clutches.
AHood
