one cylinder fouling???
Postby #20fan » January 2nd, 2006, 9:12 am
My 86 indy trail is now flooding out my r.h. cyl. it's fine at idle and for short runs but when i run for any length of time (even 2-3 miles) it loads up that cyl and bogs to the point that the only way to get it home is to pull the air box. (i know bad idea but its the only way to get her to run) HELP!!!
#20fan
Postby spire32 » January 2nd, 2006, 2:10 pm
clean or replace the needle and seat.
spire32
Postby darntutin » January 3rd, 2006, 6:00 am
Could be that the filter inside your gas tank is plugged up and inconsistantly sucking fuel, causing one side to get way more fuel then it needs
Mike
darntutin
Postby snoking » January 3rd, 2006, 1:18 pm
darntutin says what? put in a new kit in the carbs and clean them up
snoking
Postby jpiler » January 6th, 2006, 4:16 pm
Check the intake rubber boot for an air leak(crack).
jpiler
Postby #20fan » January 7th, 2006, 3:20 am
thanks all, I pulled the carbs and cleaned them real good (couldn't be much simpler) and now she's running fine. thanks again for the help!
#20fan
