When should you replace a chain?
PostPosted: February 12th, 2009, 2:20 pm
by 02xcsp700
Is there a certain milage you should replace a chain on a polaris snowmobile? I got 5000 miles on mine now and thinking it might be time before it breaks.
PostPosted: February 14th, 2009, 6:21 am
by Norsk
If your checking it, pull it out and see if it is loose or worn or ony links are broken or damaged. If it is replace it.
If it doesn't appear to be in bad shape, it may not be a bad idea to replace it anyway, since it is a cheap sense of security and you have already done the hard part with it already apart. If it breaks it gets spensive.
PostPosted: February 19th, 2009, 3:27 am
by RATMOTOR
I have 13,000 miles on the original. 02' XC700
PostPosted: February 19th, 2009, 3:50 am
by bobbygasser216
I'd replace it. They're around $85-$100 its worth not getting stranded! Plus If it breacks it could take out your chaincase and thats another $100-$200.
