My first race!! 03 ZR 900 vs. 01 Thundercat
Want to bash brands? Go ahead on this board. Profanity, personal attacks or sexual references will not be tolerated and will be deleted.
Postby zert » January 3rd, 2004, 6:23 am
My friend''s 01 Thundercat vs. my new 03 ZR 900, here is what happened. We marked off a 1/2 mile strip on a snow/ice covered gravel road and did several runs. Both sleds absolutely bone stock with same studding on 1 inch tracks. From a standing start the 900 got out about 3 sled lengths and stayed in front the whole way, hit 106 on the radar gun at 1/2 mile. Tcat was not gaining on the ZR at all. From a rolling 30 mph start the ZR jumped ahead by a sled length and slowly inched away until we hit triple digits then the Tcat lost no more ground. From a rolling 70 mph start the ZR inched ahead of the Tcat and was about 2 sleds ahead at the line. ZR ran 106 every time, Tcat was the same speed just a couple lengths back. Removed the shelf from my ZR''s airbox and did another run from a rolling start. Got ahead of the Tcat off the line and pulled away all the way through, hit 109 on the radar gun. Conditions were not ideal but ok, temperature was about 35 degrees and the road was ice on bottom covered by an inch and a half of packy snow. Now am going to install my clutch kit from Jeff Simon and go back out and run them again. Will post results. He weighs 215, I go about 180.
zert
Postby M-10 » January 3rd, 2004, 6:39 am
Hey folks. Have you ever heard of a sheep lose a fantasy race? Me neither. LOLOLOLOLOL! Bet mine is faster in the ditches and on the trails!!!!!!!! You know The real world!! Must be pretty boring on the flat and open. BOOOOORRRRRIIIIINNNNNGGGGG!!!!! What ever!!!! Do you get the feeling that I dont belive you?? Thats cuz I dont.
You wanna be dumb? Then buy a CAT!
You wanna be smart? Then buy a Doo!
M-10
Postby psycho sledder » January 3rd, 2004, 7:29 am
tink your buddies tcats runnin a bit crappy
psycho sledder
Postby M-10 » January 3rd, 2004, 7:41 am
I think the T-CAT guy musta pulled a plug wire before the race to keep things fair.
M-10
Postby Straightliner » January 3rd, 2004, 8:33 am
You should of switched sleds. The results won't be the same. I ran my friends ZR 900 with my RX Warrior his weight 162 mine 192. He beat me every time. Switched sleds him on mine, me on his RX Warrior in the lead every time. For every 7 pounds of weight heaiver you have lost 1 hp. (Later)
Straightliner
Postby Snotcicles » January 3rd, 2004, 8:33 am
Alright Zert! I knew the nine hundo was fast but that is laying down the wood. And to even keep ahead of a T-Cat is killer. You say you jumped him then ran pretty even the rest of the way, was his studs fresh? I know you said you were both runnin the same amount but did he put his in when his sled was new or did you both stud around the same time?
A picture is worth a thousand words.
Snotcicles
Postby kenlacy » January 3rd, 2004, 8:48 am
I guess It doesn't suprise me. The Thundercat is older tech, heavier, plus the pilot was heavier.
What are the HP and weights of each sled with Pilot. I would hazard to guess the power to weight ratio was better with the ZR and being that they probably are pretty much similar in HP - it comes down to weight.
Recently I was asked to play in a golf tournament.
At first I said, "Naw, I haven't been playing that well."
Then they said to me, "Come on, it's for handicapped and blind kids."
Then I thought...
Chit, I could win this!
kenlacy
Postby Big Toe » January 3rd, 2004, 1:24 pm
Glad your sled is working good for you Zert.
Big Toe
Postby SNOBALLZ » January 3rd, 2004, 2:07 pm
....just for SH!TS and GIGGLES, run against a ZR 800......would be interesting........
SNOBALLZ
Postby zert » January 3rd, 2004, 4:10 pm
I'm going to run it against anything and everything Ballz. Just need time. Who is this new M-10 loser? I'm thinkin' he doesn't have the ballz to race. Probably some punk kid blowing off his homework.
zert
Return to Trash Talkers
