'95 Polaris RXL Drive train proplems???
Postby cbaman16 » February 28th, 2005, 5:55 am
I have a 95 Polaris RXL 650 tripple and I put about 100 miles on over the weekend and started to have problems. Here's what's happening. As I was riding I notice the sled was acting kind of weird, it felt like the brake was on. I would let off the throttle and I would slow down pretty fast, like I was using the brake a little. Then I would start out again and it took more throttle than normal to get up to speed. The engine sounded right and like it was working well, so I don't think it's that. If I stopped the sled for awhile (5 min) and got back on, it would go away and then come back. Any ideas? Could the takeup cluch be hanging up, or my jackshaft, or gearbox? Bearing?? Any help would be greatly appreciated!!!
Chuck
1995 Polaris RXL 650 fuel injected tripple...
Rider of a 1990 Ski-doo 583 Formula Mach 1
AND a 1972 Ski-doo 440 Nordic
Ride hard and long... and then Fix-em...
cbaman16
Postby PolarisIndy » February 28th, 2005, 7:43 am
Hyfax melting? Next time it does that jump off into some soft snow, see if it goes away. BTW check your hyfax and see if they are shot.
PolarisIndy
Postby jpiler » February 28th, 2005, 11:14 am
The brake might be hanging up or--
Remove the drivebelt ,raise the track off the ground and rotate the whole final drive by hand by turning the secondary clutch.Many times you can locate a final drive problem this way.
jpiler
Postby cbaman16 » March 1st, 2005, 3:31 pm
I just replaced the Hyfax because they were shot, and this was the first time out with the new ones. I touched them with my fingers and didn't notice any heat, would I be able to feel it as hot if that was the problem?
cbaman16
Postby cbaman16 » March 1st, 2005, 3:32 pm
I did check out the brake, but didn't notice any problems with it. I was wondering if it could be a drive bearing or jackshaft bearing going out, so I will try lifting it off the ground and rotating the track by hand.
cbaman16
Postby RXL-XC7-RIDER » March 1st, 2005, 4:00 pm
just a guess .... remove the secondary clutch and check the jackshaft bearing.......and brake pads rotor,
let us know how you made out
[img]http://img74.exs.cx/img74/930/March-LittleValley003.jpg height=338 width=450[/img]
WILL TRAVEL FOR SNOW!!!
RXL-XC7-RIDER
Postby indyized » March 2nd, 2005, 9:46 am
If you just replaced the hyfax and this is your first ride since. I would not sweat it. it is probably just them wearing in and glazing over. Keep it in the soft stuff if you can it will come around. Check you track tension though it may have been to tight or by now the hyfax has worn and the track may be loose.
indyized
Postby cbaman16 » March 3rd, 2005, 5:14 am
Thanks for the help, it sounds more and more like what happened. I am going riding tonight and will keep an eye on it.
Thanks for all the help!!! It was really worrying me.
cbaman16
Users browsing this forum: Bing [Bot] and 15 guests
