95 polaris will not stay running
Postby BlueRider » November 14th, 2003, 12:36 am
Bought 95 polaris for my daughter 2 years ago with 3500miles
rode for half the year broke the crank. Bought new motor from
dealer.Put it in seem to run good but for only 10 min then
it seems to just die.bet you cant tell me one thing i have not
ckecked.ie.carbs fuel pump coils stator fuel lines crank seal
fuel lines tank vent line. Thankfully i have parts from junk motor
please help daughter wants to ride farther than 1 time around the
yard
BlueRider
Postby 96XCR600 » November 14th, 2003, 3:13 am
Hopefully you found out why the other motor let go. If it was in the oil pump , or leaned out too far one the carbs, You might want to check the throttle safety switches in the throttle if it starts and dont stay running at idle. Did you check the exhaust system to make sure a mouse didn't nest in there this summer ? Good luck !!
[IMG]http://img.photobucket.com/albums/v285/XC800SP/4%20Wheelin/Tenneseetrip-1.jpg[/IMG]
Quads...
2005 Polaris Phoenix (kid #1)
2004 Sportsman 700 MOBU (mine)
2004 Yamaha Blaster (wifey)
2003 Sportsman 90 (kid #2)
1989 Yamaha Big Bear 350 (spare)
96XCR600
Postby BlueRider » November 14th, 2003, 3:56 am
i checked all throttle and kill button and the pipe also
the sled is a 95 xcr 600 .Is there a ground wire i'm missing?
Like i said we have been all over this thing it acts like it
runs out of fuel or spark . If you let it set it will start.
and do the same thing.
BlueRider
Postby CheeseSledder » November 14th, 2003, 9:15 am
Sounds like a fuel problem to me, if it were electrical I don't think it would start again after just sitting for awhile. How did you check the fuel pump? Try the old one and see if it changes anything.
[blue]Yup, I seen dem Ely boys smokin crack over dere in da Bdubber, an one of em was whackin it. [/blue]:B
CheeseSledder
Postby Rozzibandit » November 14th, 2003, 11:06 am
Could it be another bent crank cause my 92 indy 650 was doing the same thing and it was the crank that was the problem
Rozzibandit
Postby harleynrw » December 6th, 2003, 7:03 am
Hi there I have a 91 indy 500 and is doing the same thing and I am pulling my hair out trying to figure this out , it just dies like someone pulled the plug on me but it does start right up. Any help if you found any will be great. Thanks Bob
Bob white
harleynrw
Postby 1fastcougar440 » December 6th, 2003, 2:59 pm
how about your plug wires?
[green]********************************************************************************************[/green]
Hearts stars and horseshoes, that leprechauns on ACID!!
1fastcougar440
Postby sledwrench » December 6th, 2003, 3:19 pm
When you say you bought a new motor, what did you get? What stayed with the sled? Ignition? Fuel tank? Stator plate? Carbs/pump; It could be something as simple as a line in the tank sucking something up after a few minutes. Then letting go after it shuts off. I have seen exhaust pipes with broken pieces inside(power valve) that plug up under load, when it quits, the debris falls off, and its like nothing was wrong.
Postby harleynrw » December 7th, 2003, 10:16 am
If it were plug wires it prob. would not start right back up. Since I wrote I have taken the gas tank out and cleaned out and I am going to try to replace the fuel pump. Is it poss that it could be getting a vapor lock? Thanks Bob , by the way this is for the 91 indy 500.
Bob white
harleynrw
Postby BlueRider » December 7th, 2003, 2:00 pm
check your tank vent lines also and fuel pick up line in the tank.
BlueRider
