Specifications Polaris Galaxy 440?
Postby andefaen » February 3rd, 2005, 12:31 am
Does anybode know the technical specifications on the engine on this snowmobile?
HP, Max RPM, Torque Top Speed, ETC....
Picked it up a couple of days ago and got it up and running.
[img]http://www.maximumsled.com/GalleryImage/GALAXY440.JPG[/img]
andefaen
Postby andefaen » February 7th, 2005, 1:18 am
Anyone? I would be glad for any kind of information about this old Polaris.
andefaen
Postby stilldoo'nit » February 7th, 2005, 12:36 pm
I've got a repair manual that has some info. It looks like Polaris made the galaxy in 1980 and 1981. Looks like the 2 years produced a very similar sled.
1980 440 Galaxy: Polaris engine made by Fugi, 432cc's, model #EC44PM-01.(In 81 engine model #EC44PM-02). Both model years should have came with a Mikuni VM34SS. Mix fuel 40:1 if not oil injection.
E.T. ignition with a point gap of 0.14in. Timing on that engine looks to be 3 degrees measured at retard(starting) position. Spark plug NGK-BR8ES with a 0.020in gap.
Chaincase Ratio 17:33 both years.
Clutch shaft center should measure 12.0 inches.
Origional belt #3211042
Mikuni Origional settings at 1000ft and -17celcius: Main jet-200. Pilot jet-35. Clip position-3. Throttle cutaway-2.5 . Increase main jet size 10 for -37 celcius. The float arms must be parallel with gasket surface of carburetor when invertedand equal in height.
Hope this info helps, even though it's not the hp and max rpms like you were asking for, Pete.
74 Tnt 340SE,went boom, now it's got a 440
76 Everest 440, restoring, many shiny pieces
75 Motoski Futura 440, minus a track, got one?
93 AC Wildcat MC 700
stilldoo'nit
Postby andefaen » February 7th, 2005, 7:14 pm
Thanks. All kind of information is welcome as i don't have any information on this sled.
The guy I purchased the sled from told me that the engine was replaced.
So it could have been an Galaxy 340 at first.
The engine is produced in japan by Fuji Heavy Ind. It has twin carburettors. Just wondering if this is an original Galaxy engine or is this an TX engine?(If not the same)
andefaen
Postby scubadiver » February 18th, 2005, 2:56 pm
i have just bought a 1980 polaris galaxy 440 it does 80 - 90 mph this old beeter runs great and fast but goes threw plugs every 3 weeks but when i put the new ones in look out!!!!!
scubadiver
Postby stilldoo'nit » February 18th, 2005, 4:16 pm
scuba what do you're plugs look like when they quit, might be running rich, or mixing to much oil in the gas. Pete.
stilldoo'nit
Postby stilldoo'nit » February 19th, 2005, 3:50 am
Hey Andefaen, what info is on the engine tag, I might be albe to find out where it came from.
stilldoo'nit
Postby andefaen » February 22nd, 2005, 6:04 pm
[quote]Hey Andefaen, what info is on the engine tag, I might be albe to find out where it came from.[/quote]
This is the info on the engine tag:
Displacement: 432 cc
Model : EC44PM
Number: 901426
Thanks for all the answers.
andefaen
Postby toocheaptosmoke » February 23rd, 2005, 12:24 pm
according to this old manual i have the engine has 50 hp and a reecomended operating rpm of 6500.
1978 Ski Doo RV 340
1979 freestyle Blizzard 5500
1980 Polaris TX 440
1980 Ski Doo Blizzard 5500
1980 Arctic Cat panther 440- WIDENED.
1981 Ski Doo Blizzard MX 5500 (parts)
1983 Polaris indy 400
toocheaptosmoke
Postby stilldoo'nit » February 23rd, 2005, 12:35 pm
That could be the original engine, it was also found in the 78' Cobra, and the 79' Cobra.
stilldoo'nit
