by U.P Sledder » December 30th, 2005, 11:28 am
I just bought a 98 ski-doo formula z 583 with 1000 miles on it, and has an ongoing problem with the 3 cam arms in the primary clutch sticking out at high speeds,{around 80 mph} when this happens your done, the sled dies and you walk unless you pop the 3 cam arms back down with a screwdriver and hammer, the previous owner had a kit installed last summer, dogs,spring..etc.. this sled is in mint condition with only 1000 miles{other than the clutch problem} CAN SOMEONE HELP ME OUT ON THIS?? IF SOMEONE HAS HAD THIS PROBLEM AND KNOWS A FIX CONTACT ME AT sdiecast@up.net, thanks jeff
