by MM700 » December 8th, 2010, 12:01 pm
[quote=FiredUpRupp]06'. Make sure you check the exhaust gaskets if they have never been replaced. If you put new ones in make sure to grind the collar in the clamp down. Over 8k I would change the speedo bearing and put the new cage protector on there. Also it doesn't look like it has the kit for the rails in the back. Make sure they ain't cracked by the back inner wheels.[/quote]
Exhaust donuts put in at dealer, last april....new jack shaft bearings...new bushings in skid, no cracks, very little rust, very well maintain sled...previous owner 60 plus yrs old...didn.t beat it.....but thanks for the advice
