Page 1 of 2
500 Limited question
PostPosted: August 26th, 2008, 2:16 pm
by bobbygasser216
I checked out USSA's rules and it kinda un clear about the hood qualifacations, Will an Indy hood be ok or will it have to be newer. Polaris's new body styles are totaly different.
PostPosted: August 27th, 2008, 7:10 am
by ussa 172m
you can pretty much run any kind of hood youwant. if looking for sponser may help to run newer stye hood. pat duchene
PostPosted: August 28th, 2008, 5:28 pm
by that 31 car
Bobby:
Hood must be from a current production snowmobile, old wedge Indy's are no longer produced, so you will need something considerably newer. Watcher built one for his son, 323 had a new style, so it is possible. The concept is to keep the stuff looking new and current.
Hope this helps
Korinek
PostPosted: August 29th, 2008, 10:00 am
by bobbygasser216
so I have to fit a edge hood and belly pan on to the indy chassis? or use a champ style hood w/ no belly pan?
PostPosted: August 29th, 2008, 10:07 am
by bobbygasser216
Ok mabye I should start over. what class would this sled fit into-
95 XCR 440sp chassis
fox shocks
stock skid
stock 04 proxr 440 motor
I'ld rather not have to change the hood and belly if I don't have to.
PostPosted: August 29th, 2008, 10:47 am
by JR-442
sell that stuff at haydays and buid F500
PostPosted: August 29th, 2008, 1:32 pm
by bobbygasser216
I do have a customers 89 500 sitting behind my dads garage I could just offer to him just to give it to me instead of paying his bill and then I've only got about $500 into it as of now.
but that's not what I wan to do. I wanna run that XCR with that 04 440 motor some how. I found the motor straps I need so I'm just about there.
PostPosted: August 29th, 2008, 1:34 pm
by watcher
you got a problem.
champ
find the stock motor, you could run limited 500, sportsman 600, ussa combined f-500/sportsman 600, stock 600, champ.
watcher
PostPosted: August 30th, 2008, 4:33 am
by bobbygasser216
[quote=that 31 car]Bobby:
Hope this helps
Korinek[/quote]
I just read over on the USSA tech forum that the hood only has to be within 15 years, but I think there rules say other wise.
PostPosted: August 30th, 2008, 7:04 am
by watcher
FRAME AND BODY
1. A rear tunnel enclosure is mandatory.
2. Hood must be an OEM production or OEM replica. Hood must not be modified in any manner that prevents it from being recognized as a current production model snowmobile. Colors and paint schemes are at the builder's discretion.
3. No carbon fiber is allowed anywhere on the race sled.
4. Belly pan/lower body is at builder's discretion.
read #2: (hood must not be modified in any manner that prevents it from being ecognized as a current production model snowmobile.)
current production model is the wording you might have missed? if it had the stock motor in it, you could use that hood, becasue ussa allows legal stock 500 or 440 sleds to run in the class.
hope this helps
watcher
