Formula 500 primary clutching
Postby kriegs33 » September 19th, 2013, 3:21 pm
How many racers run a p85 quick change clutch on their formula 500 sleds?
kriegs33
Postby Petawawarace » September 19th, 2013, 3:48 pm
Must be stock primary P-85. Specifically says NO QUICK CHANGE allowed. Any commercially available secondary.
DeJongMotorsports.com
Petawawarace
Postby that 31 car » September 19th, 2013, 4:23 pm
There is no specific mention of quick change clutch's. If you read the ISR rules you can form your own opinion.
that 31 car
Postby Petawawarace » September 19th, 2013, 4:51 pm
So I'm not exactly sure what the new ISR rules for this year state, but this is right off the EPT website and I know I voted for it after the first year of the class here in the East when the EPT rules were the ones to go by. When did this change???
1. Drive clutch must be P-85 Polaris.
2. Any commercially available driven clutch and internal components allowed.
3. Clutches and components may be modified. (The use of a quick change P-85 Polaris drive clutch
is not allowed).
4. Chain case and track shaft must remain stock and in stock location; no modifications or lightening allowed. Chain and sprocket ratio may be changed. Belt drive system is not allowed.
Now don't get me wrong, I do think the quick changes should be allowed.
Petawawarace
Postby think_07 » September 19th, 2013, 5:29 pm
I have never seen a quick change on any F500.
think_07
Postby watcher » September 20th, 2013, 1:35 am
3. Clutches and components may be modified. (The use of a quick change P-85 Polaris drive clutch is not allowed).
that is not wriiten or ever voted on at the ISR rules meeting "(The use of a quick change P-85 Polaris drive clutch is not allowed).".
The part that says "may be Modifed" allows it.
watcher
watcher
Postby fast dad » September 20th, 2013, 1:51 am
The part that says (use of P85 quick change not allowed) is in the PVR rules, not in the ISR rule book, as I read it...
TJ
[b]fast dad[/b]
fast dad
Postby 14x » September 20th, 2013, 2:08 am
drive clutch must be p-85 polaris
says nothing about using/not using a quick change
pvr going to jump on board and use the same rules as everyone else?
14x
Postby watcher » September 20th, 2013, 2:24 am
It says that a Clutches and components may be modified. by using a p-85 and making it into a quick change you modified a p-85 clutch. you can not take a comet clutch and mod it, that is not legal.
watcher
watcher
Postby Petawawarace » September 20th, 2013, 2:29 am
So the PVR rules and the EPT rules specifically say its not allowed but the ISR rules don't say that? Hmmm that should make for some interesting tech discussions at the track.
I agree 100% that where it says the clutch can be modified means you can make it a QC. And I also think they should be legal as they don't offer any performance advantage.
Quite the pickle here now
Petawawarace
