how can i stop my pull chord from sawing through my gas tank
Postby KneeDeepInSnow » March 23rd, 2002, 11:16 am
hey when i go tm y sled there was already a groove in the tank from the starter rope with some tape over it.....i took the tape off and slapped a peice of plastic over it cuz the tape was getting annoying and i didn't want to wreck the tank...... after only a handlfull of rides its already started eating this plastic.......anything i can do to stop this?
[IMG]http://i3.photobucket.com/albums/y87/KDX250/SDbrbr.jpg[/IMG]
[b][i][blue]DAYS GET SHORTER, SNOW GETS DEEPER, LIFE GETS BETTER[/blue][/i][/b]
KneeDeepInSnow
how can i stop my pull chord from sawing through my gas tank?
Postby skidoorider » March 23rd, 2002, 1:28 pm
Please forgive a dumn question,but do you always sit on the seat when starting the sled? Try pulling the rope while standing off to the side.Maybe I misunderstood the problem?!?!?! Later RB
2007 Jayco 29BHS
2007 Chevy 2500HD Duramax
Equalizer Hitch
Tekonsha Prodigy Brake Controller
skidoorider
Postby KneeDeepInSnow » March 23rd, 2002, 2:46 pm
not normally bu either way its sam thing.
ITs on the inside..... the engine is over to the left a little and the buldge in the tank is right in the path of the rope no matter what
so everytime it gets pulled it slices out the side a bit....it did the same thing with this new peice of plastic covering it....the tanks fine but i want to prevent this in the futur
KneeDeepInSnow
Postby indyized » March 23rd, 2002, 11:19 pm
Why not just bend up a small piece of light duty steel and make a deflector? You can probably mount it to the steering assembly bracket or something under there and run the rope through a ring of bent up steel and it will deflect anywhere you want. Just make sure it lines up with the exit point to make out from under the hood.
indyized
Postby PowDar » March 24th, 2002, 7:25 am
An old piece of hifax would work really good too.
I can't think of a good signature so this will have to do for now.
PowDar
Postby hilldweller » March 24th, 2002, 10:16 am
Had that problem on my 91 ext special. I took a 1/4" x 2 or 2 1/2 inch eyebolt and fastened it on one of the brake assembly brackets. Problem solved, looks like it belongs there.
2002 ZR800 CCE (carbed)
hilldweller
Postby PolarisBoy » March 26th, 2002, 9:40 am
Put on electric start kit!!!!!!!
PolarisBoy
Postby 580440 » March 27th, 2002, 8:21 am
I used an eye bolt on my 00 sno pro to keep the rope off the tank and it works good.
brad willemsen
580440
Users browsing this forum: No registered users and 4 guests
