Problem with my '04 F7 EFI snopro please help!
Postby MADTURK » October 24th, 2003, 6:06 am
No, the studs are not rubbing on the tunnel. I hope nothing is wore out yet, the sled only has 10 mi. on it.
Thanks for your help-
MADTURK
Postby Snotcicles » October 25th, 2003, 1:43 am
Sounds like you glazed your belt. Clean clutches with brake cleaner and wind a new rubber on it. Might want to bump up the prelaod on your driven also.
Snotcicles
Postby Turkster » October 25th, 2003, 3:41 am
You are running either too steep a helix or your secondary spring is sacked or you need to run more secondary pretension. What is happening is your hooking up hard & your secondary is sensing a big load & is upshifting too fast. This sucks the belt down into the secondary putting your drivetrain into a higher ratio & bogging it down. It is an easy fix & I 100% guarentee for certain for sure by adjusting the secondary it will cure your problem!
Turkster
Postby MADTURK » October 25th, 2003, 4:04 am
Thanks- I will try that.
Why do they call you Turkster? (they call me Turk)!
MADTURK
Postby sledwrench » October 25th, 2003, 4:30 am
Are you positive it was slipping? After a few runs at the grass drags, the ground gets very loose. Does it slip all the way to the end? Make any noise? Could it be a spline problem, or shaft spinning inside the cogs themselves?
Postby Loudhandle » October 25th, 2003, 7:38 am
2 miles is nothing these days Spudnuts pulled me around Burntside lake on his ZRT mod while I was knee boarding.
Keepin the flipper wicked since 1978
Loudhandle
Location: F-6 faster than all 700's faster than most 800's
Previous
