BR9ES or B9ES???
PostPosted: December 12th, 2001, 11:38 am
by MxZx440
My Ski-Doo racing handbook says that thestock pug for the MXZx440 is B9ES.My question is isn't this bad for the ignition?
Thnx in advance.
MxZx440(Adam)
BR9ES or B9ES???
PostPosted: December 12th, 2001, 11:44 am
by H20skipper
Makes no difference on performance, same plug basically. The "R" stands for resistor, meaning it won't interfere with any sort of unprotected radio type signal(like if u had that plug in a car and U had an unprotected radio signal, which is very unlikely though).
BR9ES or B9ES???
PostPosted: December 12th, 2001, 2:09 pm
by snopro38
you must run (R) plugs with digital ingntion.
BR9ES or B9ES???
PostPosted: December 12th, 2001, 9:47 pm
by MM700
Ok, sno-pro, who has digital ignition systems ????
Do any stock sleds on the market have them????
And what would happen if he ran those plugs instead of (r) plugs????
BR9ES or B9ES???
PostPosted: December 12th, 2001, 11:35 pm
by swissbliss
I RUN BR9EV IN MY MXZX,THERE A LITTLE MORE EXPENSIVE,BUT WILL NEVER FOUL OUT.
BR9ES or B9ES???
PostPosted: December 12th, 2001, 11:41 pm
by ArcticEd
Who has Digital ignitions??? Uh, just about everyone..........
BR9ES or B9ES???
PostPosted: December 13th, 2001, 4:29 am
by michahicks
It's said by the techy types that the RF (static)
created by non resistor type plugs COULD POTENTIALLY cause a digital ignition system to misfire. Don't know if anyone has actually documented this happening. The best reasons to run resistor type I can think of would be mainly for on board electronics (communication gear, GPS's come to mind)and people trying to watch TV or listen to their radios in homes near where you are running your sled. There is no performance difference between the 2 types. Most people recommend the R types because they are designed to prevent any trouble, as compared to the non resistor, and their POTENTIAL for causing rouble.
AL
BR9ES or B9ES???
PostPosted: December 13th, 2001, 10:06 am
by MxZx440
Hey thanks for the replys guys,I knew there wasn't any performance gain i was just worried about the ign.Doing something funny.I have BR9ES in it know.SWISSBLISS you run BR9EV I'l have to try those if I start fouling.
Thanks
MxZx440
