SRX VS. ZR 800 Cross Country
Postby 250exdude » January 12th, 2002, 11:36 pm
I saw these 2 machines race 3 times today thought 4 sure the 800 would spank the srx but i was wrong they would be the same until midrange then the srx would blow bye. both of these machines were stock. i was im pressed with the srx.
ride it like you stole it!
250exdude
Postby Pacman » January 13th, 2002, 12:13 am
I had a 01SRX700 (put 4000kms on it) and now I have a 02ZR800EFI with only 25 miles.
It seems to me that the ZR pull a little more down low (first 400') but I can tell that the SRX has more juice when cruising at 70 mph and hit the trottle!!!
As far as top end, I can't tell as my ZR still new (break-in period)...
but I'm sure the SRX is faster if properly jetted!
Al. (02ZR800EFI)
As long as you ride!!!
Pacman
Postby polarisman415 » January 13th, 2002, 11:48 am
Yeah usually a Triple has about a 100cc more power than a twin. Example, a 600triple can run over a 700twin. 700 beating an 800 in this case. An extra piston does a lot in the HP department. I also think they run a lower gear ratio in most triples too.
The XCR800 Kicks ass
polarisman415
Postby CATPPL » January 13th, 2002, 12:21 pm
The SRX is a sweet looking sled, i would own 1.
I really like the blu
All the good ones are gone!!
CATPPL
Postby Xtreme XC » January 14th, 2002, 1:15 am
It's not so much that the extra piston gives the extra HP, it's the extra 2 pipes that give it the extra.
Postby Drewman » January 14th, 2002, 4:38 am
Also the shorter lake racer suspension on the SRX has much less drag (aero and friction) at higher speeds than taller mogal masher suspension on the ZR800cc.__________DREW
[green][b]I LOVE THE SMELL OF TWO-STROKE IN THE MORNING[/b][/green]
Black 01 ZL800esr, Ya I got mirrors, all the better to see how far back you are
Drewman
Postby Uker2 » January 14th, 2002, 7:18 am
My '01 SRX vs '01 ZL 800 ESR was a toss up depending on who got the start. The ZL was studded and had some mild clutchwork. This was on a lake with a few inches of fresh powder. Unfortunately, this was last year. I have no stories to tell about this year!!!!
Uker2
01'SRX
Uker2
Postby ZR800XC » January 14th, 2002, 11:32 am
like previously mentioned, the SRX is a lake racer and the ZR a mogul masher....BUT, with the suspension tuned in the ZR has the umph to hang with the 700 triple Mach 1s...which is enough to edge off them Blue Piles of Crap. Come play on the trail, then we'll see who's left in the dust........HEEEEEHAWWWWWW
Postby MOUNT-CAT.KING » January 14th, 2002, 12:46 pm
I agree with Xtreme XC, Im asking, ZR 800 vs Viper 700 single pipe, the story will not be de same, The Viper,"is suppose RAM-AIR" better be wide open!!!
SRX running good on hard coatting lake, but just put 6" of powder and is speedo gos down!!
*This Message was edited on 14-Jan-02 05:48 PM by MOUNT-CAT.KING*
MOUNT-CAT.KING
