4stroke engine vs 2stroke engine weight question
Postby NorthernSkunk » October 12th, 2006, 10:01 am
...when I think about runnin a 4 stroke engine compared to a 2 stroke engine I always am thinkin that the 4 stroke engine is a heavier engine than a 2 stroke engine(yes or no?)...I am pretty sure that I have read that a 4 stroke engine is indeed a heavier powerplant(how much? comparin say the F-10 to the apex engine?)...so then I think why would I want that extra weight hangin out over the skiis..it can't be good for handling......so how much heavier is the 4 stroke engine itself? jus askin
NorthernSkunk
Postby raisinL » October 12th, 2006, 10:03 am
Never picked one out of a 4 to tell ya but pull alot of two smokes out.
raisinL
Location: Yamaha The most talked about snowmoible on the net
Postby kenlacy » October 12th, 2006, 10:08 am
some amount of more pounds - whats the difference - the weight is likely up front on the cats from other parts - like exhaust and so on. The exhaust and silencer carries a lot of weight - all of that onthe Yams is under the rider and back.
Then I thought...
Chit, I could win this!
kenlacy
Postby Xtreme XC » October 12th, 2006, 10:09 am
Anywhere from 50-80 lbs heavier
Postby Icehole » October 12th, 2006, 11:30 am
When Yam has ta comply with 4st hydro carbon emission mandates you can add another 15-20 lbs and deduct bout the same in hp.....the wallowin sows er as good as they're gonna get right now
Icehole
Postby Yamanator » October 12th, 2006, 1:45 pm
[quote=Xtreme XC]Anywhere from 50-80 lbs heavier[/quote]
Is that so proffessor? In that case care to explain why the Mach and the Confusion 900 were so close to the Apex weight?
Max out or black out.
Yamanator
Postby Icehole » October 12th, 2006, 1:53 pm
I see tator is still mouth agape swallowin Yam's immorally deceptive weight claims.....could drop a krap soaked phazer in dat big dam piehole
Icehole
Postby Yamanator » October 12th, 2006, 3:59 pm
[quote=Icehole]I see tator is still mouth agape swallowin Yam's immorally deceptive weight claims.....could drop a krap soaked phazer in dat big dam piehole[/quote]
I'll always trust in you to talk about putting large objects into the mouth Licehole. Seek help my friend...
Yamanator
Postby kenlacy » October 12th, 2006, 4:13 pm
[quote=Yamanator][quote=Xtreme XC]Anywhere from 50-80 lbs heavier[/quote]
Is that so proffessor? In that case care to explain why the Mach and the Confusion 900 were so close to the Apex weight?[/quote]
Cause Yam went lightweight with just about everything else. I would be willing to bet the Yam Chassis is quite a bit lighter than the Poos and Doos. Not to mention titanium and magnesium lightweight parts in the drivetrain and so on.
Then I thought...
kenlacy
Postby Turkster » October 12th, 2006, 4:49 pm
Had light sleds & heavy sleds. The heavier sled is way more stable & easier to handle at high speeds. Lighter sleds get squirrely & do not feel planted. Might wanna try hitting a gym to increase upper body strength?
Turkster
