ZRT600 with to much power "Help"
Postby Speed demon » November 30th, 2001, 8:36 am
My friend need help to bring down the power on his ZRT600. Someone told me to drill a 7/16" hole on top of all three cylinder. Is this the right thing to do?
Speed demon
Postby PolarisIndy » November 30th, 2001, 8:45 am
Yes....
PolarisIndy
Postby Elk » November 30th, 2001, 9:12 am
Speed demon
I hope you are joking. You do not want to drill any holes anywhere in the engine. Do not touch you friend's sled. Who ever told you to drill holes in the engine, should have holes drill in their head!!!
My sled 1995 ZR700 Not my web site but a good one for Mainers:[url]http://www.sledmaine.com/[/url]
Elk
Postby RyMachZ » November 30th, 2001, 9:14 am
Why would you wanna down the power anyways....
RyMachZ
Postby KneeDeepInSnow » November 30th, 2001, 9:14 am
not a clue, but drilling a 7/16 hole in the top of each of the cylinders doesn't sound like a very good idea.... wouldn't that just open them up completly and get metal all over and in the cylinder?? check the dealer or somthing but doesn't sound very good to me.......wouldn't you'd lose like half of your compression,sale value, and efficiency.............
KneeDeepInSnow
Postby 2k2mxz6 » November 30th, 2001, 9:21 am
Take the rotax motor out and put a suzuki motor back in,that should solve you're power problem alright,cause suzuki aint got none.
2k2mxz6
Postby PolarisIndy » November 30th, 2001, 9:21 am
Sure ya do.... It's called External Porting... Do it and let me know how it works for ya... Drill as many holes as you want... The more the better. Oh and for that extra reduction in power go ahead and pour some sugar in your gas. About 1/2 cup per gallon should do the trick...
BTW, JK....;)
PolarisIndy
Postby Elk » November 30th, 2001, 9:26 am
Drilling holes in the top of the engine would destroy all the compression, all the coolant would leak out, Result no power, destroyed engine.
*This Message was edited on 01-Dec-01 12:05 AM by Elk*
Elk
Postby Mainecat » November 30th, 2001, 9:31 am
it will only work if you bore a forth hole in the operators head.
Mainecat
Postby snodrifter » November 30th, 2001, 9:39 am
Lengthen the throttle cables---you could just disconnect the gas lines
snodrifter
