Ceramic/Teflon Coating-pipes/pistons
Postby ccperformance.com » December 7th, 2001, 2:31 pm
Tired of looking at your rusty pipes? Better yet, are you putting new pipes on your sled? Your new pipes are likely larger volume and made of thinner metal than the ones you are taking off. With this in mind it's very important to protect your new investment and keep the heat in the pipe more efficiently than the heat shields on your stock pipes.
Ceramic coating will protect your new pipes from rusting and your old pipes from rusting again. Additionally they'll keep the heat in your pipe and dramatically lower your under hood temps so you can make the horsepower your expecting to make......For more info or pics contact info@ccperformance.com or go to www.ccperformance.com or call 248-682-2453
ccperformance.com
Postby ostapowich » December 10th, 2001, 7:03 am
TRY WRAPPING THEM.
ostapowich
Postby Flatout » December 11th, 2001, 11:30 am
Most of the rust damage is inside the pipe!
I would be impressed if they could ceramic coat them inside and out!
Flatout
