Elan air filter?
Elan air filter?
Postby badercarma » January 9th, 2003, 11:10 am
Hi, I just bought a 1971 Ski-Doo Elan 250e, the motor runs really good but I think its running to lean because it doesn't have an air filter (after riding it for a while it will bog down and die until it cools). The person I bought it from said it's not suppose to have an air filter but I don't think I believe him. Is there any place I could get an air filter or what should I do to fix this?
*This Message was edited on 09-Jan-03 04:12 PM by badercarma*
1971 Ski-doo Elan 250
My Sled
badercarma
Elan air filter?
Postby JOHN327 » January 10th, 2003, 7:04 am
BAD YOU MAY BE GETTING SNOW IN THE CARB IF I
REMEMBER IT SPRAYED GAS ALL OVER THE SEAT AND I DONT THINK IT HAD A AIR CLEANER GODD TRAIL BREAKER IN ITS DAY WAS LIKE RIDING A FOOTBALL
JOHN
JOHN327
Elan air filter?
Postby skidoodler » January 10th, 2003, 11:10 am
The elans did have an air breather,but did not have an actual air filter.Itwas only a silencer. 71' should have a tillotson carb.check your high and low speed jet settings,what are you mixing your fuel at,check heat range of spark plug,check ignition timing.Hope something helps.
caught in a"BLIZZARD"
skidoodler
Elan air filter?
Postby harry_29_57 » January 11th, 2003, 5:55 am
no air filter on elans . thats probably your problem is the needles. i have a twin but i remember the singles spitting gas if they are not set right.
harry_29_57
Elan air filter?
Postby badercarma » January 12th, 2003, 9:20 am
Well I made a fourwheeler air filter fit it. It hasn't overheated but it still bogs when u give it gas, what should I set those screws at?
My Sled
badercarma
Elan air filter?
Postby skidoodler » January 14th, 2003, 10:26 pm
You should start at about 1and a half turns out and go from there.In for less fuel,out for more,Use a new spk plug,adjust,go for short hard run,check plug,repeat if needed.Plug should burn chocolate brown when working right.Patience is a virtue.
skidoodler
Elan air filter?
Postby harry_29_57 » January 15th, 2003, 10:16 am
skidoodler i think you got it. iand a half is just about right. i would toss the air filter .they were not designed to run one.
harry_29_57
