1971 EXT 290 NOS clutch available for sale/trade
Postby Pantera » February 1st, 2006, 6:30 am
Looking for the stock HEX clutch for a 1976 Cross Country Cat. The machine I have had it replaced with an NOS 1971 EXT 290 clutch, Part# 0100-154. FYI: The 1976 CCC uses different ramps than all the other machines and are no longer readily available so that is really all that I need since I have plenty of HEX clutches lying around.
The 1971 EXT 290 clutch will probably be for sale after I find the proper 1976 CCC clutch.
Thanks, Pantera
Snowmobile the America that others pass by....
Pantera
Postby Snojet Steve » February 1st, 2006, 6:57 am
I wonder, does anyone offer blank ramps anymore?
Snojet Steve
Postby AHood » February 1st, 2006, 11:28 am
yep they do
AHood
Postby Pantera » February 2nd, 2006, 6:03 am
My friend who also has a series of CC Cats said he knew of a place that used to have blanks and was going to investigate that option. He needs a set also and his situation is even more depressing. In the process of doing his restoration the clutch was lost/misplaced with others at his own dealership when he had so many projects going on at once, so he HAD his and lost it!!
Pantera
Postby Pantera » February 2nd, 2006, 6:04 am
So where do we go for blank ramps?? Names & numbers please.... :)
Pantera
Postby ZR800XC » February 2nd, 2006, 11:30 am
a guy in Minnesota has blanks
Paul James
[email]pauljames230@msn.com[/email]
763-245-0955
He says he also has some factory patterns if you have the P/N. Original P/N for your Cat is 0146-341. I don't have the ramp number, but you probably know that anyway. Along with the weight set, which is still available from Cat 0146-123. And it just takes the green spring that every other cat took....again, you probably know this......
Drop me an email if that clutch becomes available!
[email]Twister76@core.com[/email]
Postby ZR800XC » February 5th, 2006, 4:19 am
So, could this guy hook you up? Or what?
Postby Pantera » February 8th, 2006, 6:01 am
Been a little busy and haven't tried contacting him yet. Maybe this weekend.
Pantera
Pantera
