why ???
why ???
Postby yamaha440 » March 15th, 2006, 8:11 am
on my citation ss when you are holding the throttle wide open
The sled gets up to speed and then all of a sudden It loses all power and starts blowing so much smoke you cant even see whats behind you but as soon as you let of the throttle it all clears up
just replaced points condencers throttle cable and cleaned the carbs
could it have been something Id done or screwed up all help
appreciated greatly thanks
yamaha440
why ???
Postby roosman » March 15th, 2006, 9:13 am
Sounds like a faulty oil injection. Pumping too much oil at WOT. Pull that oil injection, plug the lines and run mix gas.
roosman
why ???
Postby AHood » March 15th, 2006, 10:30 am
does it have a mikuni on it?
AHood
why ???
Postby yamaha440 » March 15th, 2006, 11:40 am
The oil pump died 2 years ago running 40:1 seems ok
The carbs are mikuni 30 or 32 mil have to check though
yamaha440
why ???
Postby cory49 » March 15th, 2006, 11:40 am
[quote=AHood]does it have a mikuni on it?[/quote]
It should, besides he mentioned unscrewing the caps on top of the carbs when he was installing the throttle cables..
[b]Sledless[/b]
cory49
why ???
Postby cory49 » March 15th, 2006, 11:41 am
Disregard my previous post, as he and I posted at the same times..:)
[b]Sledless[/b]
cory49
why ???
Postby 74accheetah » March 15th, 2006, 11:56 am
Yamaha, why didn't you add this info to your original question?
'The oil pump died 2 years ago running 40:1 seems ok
The carbs are mikuni 30 or 32 mil have to check though'
I'm not a Citation expert by any means, but how is the oil injection designed? Is there one line or two from the pump? Does the pump lube the crank as well as the intake?
Just trying to help...
Jb
74accheetah
why ???
Postby yamaha440 » March 15th, 2006, 12:13 pm
sorry never thought of it the pump has just one line and it just
lubes the intake theres a diagram of the pump if you click on the link on the bottom of cory's replys does only having one line matter even though the pump isnt doing anything or is it
yamaha440
why ???
Postby ZR800XC » March 15th, 2006, 1:00 pm
if your oil injection is unplugged, then it can't be the culprit. You do have it blocked off at the intake so it can't suck air, I take it! The oil pump is on the recoil on your sled, right? If it all started happening after your tuneup then I'd recheck everything. It could even be a faulty condensor...as cylinder pressure rises your ignition may not be powerful enough to light up the plug.
Could also be in your carb...check and make sure you installed everything correctly. Did you put the e-clip back in it's original position on the needle? I believe yours should be in the second position from the top. Even something as small as a vent tube pinched off could do this........
why ???
Postby degasus » March 15th, 2006, 1:06 pm
I would do a compression test and possably replace the rings
degasus
