SRX Hydralic Brake???
Postby duncn70 » April 6th, 2006, 2:16 pm
Does anyone know where I could get a Hydralic brake to bolt right onto the hold bracket on my SRX? Do any other Yamahas have a hydralic brake that will bolt in place? Thanks, Mike.
[b]Sleds I own:[/b]
[ul][*]1977 Yamaha GS 340 (mint for sale)[*]1973 Ski doo TNT Silver Bullet 340[*]1976 Rupp Nitro 440 L/C[*]1979 Yamaha SRX 440
[/ul]
[COLOR=#ff3300]IF IT DOESN'T GO [b]BAAAAAAAAAAAAAAAAAAAAAAP[/b] IT'S JUST A TRAIL SLED!!![/COLOR]
[COLOR=#0000ff]Check out the T-Jets.[/COLOR]
duncn70
Postby sled_king » April 7th, 2006, 1:28 am
none that i'm aware of. yamaha loved using cable brakes on the majority of their sleds for years. the centre to centre distance for bolts on the srx brake caliper is small. i ended up building a stainles steel D shaped mounting bracket and bolted that to the chaincase then bolted a Hearst Airheart caliper to the bracket. i tipped that set up with a willwood master cylinder and a stainless steel braided hose. the system works much better that the stock cable brake plus it is much safer.
pm me your email addy and i will shoot you a couple pics of it, if you wish.
sled_king
Postby ZR800XC » April 7th, 2006, 4:13 am
The 72 SRs had a hydraulic brake, right? It used the same master cylinder as one of their bikes, and can't really remember the caliper. I don't know if this would bolt on to the SRX or not? Likely won't pick one up cheap?!
Postby crwdog » April 10th, 2006, 5:34 am
I removed my SR292 chain case and hydraulic break set up. Converted to the lighter Exciter chain case. Made my own bracket and bolted a honda motorcycle single piston caliper onto it. Used a resivor and lever from a 2002 SXR yamaha. - just stuff laying in the local salvage yard
crwdog
Postby duncn70 » April 10th, 2006, 11:47 am
What bike do you think has the a caliper that might work on it? Thansk for the info guys.
[b]Sleds I own:[/b]
[/ul]
duncn70
Postby crwdog » April 11th, 2006, 5:36 am
I cant recall which bike it was, but it was the front brake. Bolt pattern width was the same as the chain case I used. Just had to mill out a spacer block between the case and brake. Had to make another spacer between the caliper halfs. Pretty simple stuff
crwdog
