motor sounds like a four stroker
Postby jake_arcticcat » September 25th, 2006, 3:38 pm
i guess this would be more of a question for ahood. Ive got two 36 mikunis with 250 mains and 25 pilots on my ss 440 f/c yammy(reeded). whenever it runs it sound like a fourstroke( i toke the silencer off the pipe). Just wondering wat jets should be in it.
jake_arcticcat
Postby AHood » September 25th, 2006, 5:15 pm
hard to say. i setup a 440 reed yami with 40 mm keihin pwks but thats no help. idk your main jet sounds small. i run 260+ mains in my modded 340 fan. the 25 pilots dont sound out of wack do you know what size needle jet and what number needle your running? how do the plugs look? and are you running this now in somewhat cool weather. your always gonna run richer if its not cold out and your jetted for winter.
AHood
Postby Snojet Steve » September 26th, 2006, 10:44 am
I toked from some flex pipe last weekend.
Snojet Steve
Postby jake_arcticcat » September 26th, 2006, 10:55 am
the carbs are off a traill twister so watever needle jets they got i never changed them
jake_arcticcat
Postby Centricity » September 26th, 2006, 11:53 am
I just toke from a ZigZag.
Centricity.
Sledless...
Centricity
Postby Spuds » September 26th, 2006, 12:02 pm
Sounds like ya put a Phanzy in your vintge there
Keepin the flipper wicked since 1978
Spuds
Postby snoking » September 26th, 2006, 1:27 pm
brass, I keep braking the glass
snoking
Postby ZR800XC » September 26th, 2006, 1:27 pm
but........how does it run? If it runs like******and has no power, you have too big of mains. If it hesitates, or bogs when ya peg the flipper, you're too lean. A "FAT" sound usually means rich jetting. A crisp sound would mean you're really close.
It's also said when a two stroke "four strokes" it excessively rich. I'd guess this is your problem. Check your plugs, as AHood said. Check your piston wash as well, if you're as rich as I think you are you'll have excessive wash.
Postby jake_arcticcat » September 26th, 2006, 3:32 pm
it wont idle at all but runs half a$$ed when wide im think of switchin to 310 mains or something. I f i run a 310 in one side and a 330 main in the other will it blow up or are they close enought for now.
jake_arcticcat
Postby AHood » September 26th, 2006, 3:50 pm
[quote=jake_arcticcat]it wont idle at all but runs half a$$ed when wide im think of switchin to 310 mains or something. I f i run a 310 in one side and a 330 main in the other will it blow up or are they close enought for now.[/quote]
have you ruled out leaking crank case seals. thats a typical sign. 310 is likely too rich and 330 would just be way too rich. it wont hurt anything but will likely foul plugs and not run well. and agaian you need to check your plugs and piston wash those can tell you more than any of us can by just guessing at what might be the problem.
AHood
