Heat Light Temp
Heat Light Temp
Postby ZRT7c » January 25th, 2006, 3:27 am
Hello i was wondering if anyone know what temp my heat light should come on at. i am asking because i just bought an electric heat guage for my sled and im anctious to know what to red line my guage at so i know when its too hot. i might have to look at my light sending unit again but i don't believe it says the tem on it for when it comes on thanks C.J. any help is appreciated
[green]STAY GREEN[/green]
[img]http://www2.propichosting.com/Images/502164/1.jpg[/img]
ZRT7c
Heat Light Temp
Postby ZRT7c » January 29th, 2006, 10:36 am
I did look in my service manual under my coolant temp sending unit and it said something about 230 degrees does'ent that sound a little hot
ZRT7c
Heat Light Temp
Postby northern_sled_freak_69 » January 29th, 2006, 12:12 pm
what u could do is get an infered heat gun and run er up to temp and then take a reading on the spot and add 20'c or 50'f degrees on it
