Problems...
Problems...
Postby JustDawg08 » January 27th, 2006, 11:17 am
I got a polaris pro x 2001-2002 440, its a racing sled, but we dont race it anymore.
Whenever we get to 6,000 rpms it always bogs down and it wont go anyfaster, I mean sometimes it will luckily make it past and just start haulin, but most the time it bogs down, same as when we try to take off fast. We tried changing the plugs, new belt, greased some stuff with the clutch, and my brother in law adjusted the tension in the clutch or something. But we just cant seem to get it to work right, any suggestions?
JustDawg08
Problems...
Postby snoking » January 27th, 2006, 12:20 pm
it sounds like a fuel problem,have you cleaned the carbs?
snoking
Problems...
Postby JustDawg08 » January 27th, 2006, 12:57 pm
nope, my dad was like... oo I dont want to go tearing the whole sled apart if we dont know what it is... I actually thought that it was running on one cylinder from time to time, but yeah Ill tell my dad to try that once, any other suggestions if this dont work?
JustDawg08
Problems...
Postby JustDawg08 » January 27th, 2006, 1:04 pm
Alright, I just called my brother in law who previously owned the sled he had similar problems, he said when he had it he cleaned the carb and took it apart several times changing jets and stuff. Eventually he took it to someguy who fixed it, the guy never told him what he did to it... anyways we still have the problem... we will be working on it tonight so any other suggestions?
JustDawg08
Problems...
Postby northern_sled_freak_69 » January 27th, 2006, 3:16 pm
hmmmmmmmm well take the belt of and slowly ease on the clutch and then see if you can get it over 6000 and if thats the case start clutchin
Problems...
Postby JustDawg08 » January 28th, 2006, 8:15 am
we already did a bunch to the clutch and that aint the problem we found out.
last night we tested it with the a pressure tester and the cylinders were fine. any other hints?
JustDawg08
Problems...
Postby northern_sled_freak_69 » January 28th, 2006, 11:15 am
take the belt of ease on the gas so it doesn't hammer the clutches together and then see if you can get it over 6 grand
Problems...
Postby cosmic muffin » January 28th, 2006, 1:38 pm
Had a buddy, was pretty sharp,spend a ton on what he thought was a clutch problem! Discovered a bad plug wire! Good Luck!
cosmic muffin
Problems...
Postby northern_sled_freak_69 » January 28th, 2006, 3:19 pm
but if its also not stock clutching then it will cause a bog down and it might not be able to over come then ramps
Problems...
Postby JustDawg08 » January 30th, 2006, 1:11 pm
like we say its pretty sure its not a clutch problem
JustDawg08
