Engine dies out!
Engine dies out!
Postby Yamahadude70 » February 6th, 2006, 11:09 am
The engine on my yamaha bravo runs fine for about 3 mins. then it bogs out and dies. if i wait an hour it starts up fine and works for another 3mins. i had the jug off and noticed a biuldup of fuel in the bottom of the crankcase. i thinkthe engine is flooding itsself. what would cause this becides a leaky float (ckecked it).
Yamahadude70
Engine dies out!
Postby northern_sled_freak_69 » February 9th, 2006, 2:17 pm
tooo big of jet and there is supposed to be fuel in the crank just depends how much fuel is down there so my ? is this how much was down there
Engine dies out!
Postby Yamahadude70 » February 12th, 2006, 4:46 pm
there was about an inch of fuel in there
Yamahadude70
Engine dies out!
Postby jammo » February 13th, 2006, 1:58 am
sounds like the needle and seat are worn in your carb, or simply a sticking float. When you crank over your engine, the fuel pump seems to send fuel to a carb that isn't regulating fuel for idle speed, probably more like wide open. Wide open fuel flow with idle air flow equals "bog and flood."
jammo
Engine dies out!
Postby Yamahadude70 » February 13th, 2006, 4:21 pm
yup replaced them yesterday... fixed the prob
Yamahadude70
